Login Error
Close
3 Reasons to Use a Circuit Analyzer in Your Home
by DoItYourself Staff
A basic tool in any electrician's test tool kit, a circuit analyzer is a device that is used check various wiring conditions. It can determine correct wiring and polarity reversal. It can also determine arc faults and if there's no ground. You can also determine if there's a dirty power, poor ground or even ground noise among other wiring problems that can be found in the home or anywhere else that makes use of electricity.
If is not a bad idea for you as a homeowner to keep a circuit analyzer at home to run simple tests on your electrical circuits. This tool is easy to acquire at your local hardware or electronics store. Now, let's take a look at the reasons why you should use a circuit analyzer in your home.
1. To Check for Correct Wiring
You can use a circuit analyzer when you think that the wiring you did is not correct. For example, if you are extending wires for your speakers or extending electrical wires for a certain appliance and you are not sure whether you have connected them properly, you may use a circuit analyzer to check. It is also ideal to use a circuit analyzer to check if there's any bad wires in the circuit, meaning a chipped or cut wire.
2. To Check for Reverse Polarity
A reverse polarity is the complete opposite of a normal polarity. But what does normal polarity means? In electronics, it means that if you have correctly hooked up the positive terminal to the positive wire and the negative wire to the negative terminal. Now again, if you are unsure if you have hooked the wires and terminals correctly, the best way to know is to use a circuit analyzer. It will tell you if you are encountering a reverse polarity in which you hooked the negative wire to the positive terminal and the positive wire to the negative terminal.
3. Use it to Test Arc Fault
A circuit analyzer is also the best solution to try to determine if there is an arc fault. Now you may be wondering what an arc fault is. An arc fault happens when there are corroded or loose connections in the circuit. When wires are making intermittent contact and thus causes sparks or arcing between the wires, then you have an arc fault. It is important that you determine this right away because continuous sparks and arcing will later translate into heat. When that happens, the insulation of the wire will break down and it can actually trigger an electrical fire. So even before that happens, make sure to grab a circuit analyzer and test it out. If there is an arc fault, make sure to unplug items or turn of your circuit breaker and look for the culprit.
 forum activity
