3 Reasons to Use a Motion Sensor Light Switch
Installing a motion sensor light switch has several benefits. They are relatively inexpensive and simple to install. Here are a few reasons you should consider using these types of switches in your home.
Saves Money
Many of us are guilty of leaving on lights when they aren't needed. A motion sensor switch will sense when there is movement in a room, turning the lights on. When the movement stops for a set period of time, the lights will switch themselves off. This prevents unoccupied rooms from using wasted energy.
Eco-Friendliness
Since energy is only being used when the sensor detects movement in a room, installing the motion sensor switches helps save resources. Many models will feature overrides that prevent the lights from being turned on if there is adequate daylight. You can also set the amount of time the light will stay on once the room is unoccupied again. It's a simple way to make your home more green.
Added Security
Many people have used motion sensor lighting outdoors, but using them indoors can create a safer environment as well. Since the switches will automatically cut on the lights with motion, you won't have to worry about rooms staying dark all the time. Outsiders will see the lights cutting on and off as you move through the house, letting people know the home is not empty.
