3 Reasons to Use Cinder for Rock Driveways
Installing a rock driveway can provide you with a beautiful entrance to your home. Using cinder rock as the material for the driveway can present you with a number of unique benefits. Here are a few reasons that you may want to consider using cinder rock for your driveway.
1. Light
One great benefit of this type of rock is that it is light by comparison to other types of rock. You will be able to lift and handle it much easier than other types of rock that you could use for your driveway.
2. Porous
Cinder rock is one of the most porous rocks that you could use for a driveway. Since the rock is porous, it will allow the driveway to drain very easily. Instead of worrying about water running off the driveway, it will just soak down below it.
3. Shape
Another great feature of cinder rock is that it comes in a variety of shapes. Every rock is irregularly shaped and therefore, it will give you a very unique look. No two cinder rock driveways will look exactly the same because of the irregularity of the shapes of each individual rock. This allows you to customize your driveway and create something different in the neighborhood.
