Login Error
Close
3 Signs that a Car's Control Arm is Going Bad
by DoItYourself Staff
If you are concerned that your control arm is starting to go bad, you will need to address the issue as quickly as possible to avoid further complications. There are some obvious hints that you have a problem with your control arm, but knowing what to look for will help solve the issue faster.
1. Noise
When you are driving your vehicle and going over a bump or pothole in the road you will hearing clunking noise. Ride smooth degrades when the control arm is wearing out and you will inevitably notice a reduction in the quality of your driving experience.
2. Movement
Another obvious symptom of a failing control arm is too much wheel movement. If you place your hands on one of the wheels and push it you will feel more of a wobble. This is likened to the same symptoms of a bad CV joint or ball joint. There should be no play in the wheel beyond the acceptable level, so if you feel too much movement, have the car checked.
3. Steering Wobble
Driving at higher speeds of between 45 and 60 miles per hour will demonstrate control arm failure by exhibiting a wobbling in the steering wheel. This is similar to when the tracking and balancing is off and the steering wheel wobbles heavily when you drive. If you are sure your tracking and balancing is fine, the control arm is probably the cause.
 forum activity
