Login Error
Close
3 Textured Concrete Finishes: Pros and Cons
by DoItYourself Staff
Textured concrete finishes have become very popular because of the vast array of choices that are now available. Each type of textured concrete finish has some unique features that could be considered advantages or disadvantages. Consider the following pros and cons about stamped concrete, stenciled concrete and the broom-style textured finish.
1. Stamped Concrete
One of the most common types of textured concrete finishes is stamped concrete. This is created by stamping patterns into the concrete to get the same look as pavers, tiles, bricks or many other types of surfaces. One of the advantages of this type of finish is that you can create a very luxurious look for a fraction of the cost of going with the real thing. For example, you could have a stamped concrete surface installed that looks just like slate tile. If you actually installed slate, you would most likely pay quite a bit more money.
One of the disadvantages of this type of surface is that it tends to crack on the lines. With so many impressions in the concrete, it can create areas of weakness in the concrete. It is also very difficult to repair stamped concrete if it does crack in the future. Another disadvantage of stamped concrete is that you have to have special equipment to complete this process. This is not an ideal project for a do-it-yourselfer to attempt.
2. Stenciled Concrete
Stenciled concrete employs stencils in various shapes to create designs in the surface. One of the advantages of this process is that it is quite a bit easier than stamping concrete. In addition, you can complete this task much faster than if you were trying to stamp it. Another advantage is that the designs do not go down into the concrete as much as with stamping.
One of the disadvantages of stenciled concrete is that you will have a limited number of stencil options to choose from. Likewise, there is a good chance that the pattern could repeat frequently in the stencil, which could be noticeable in a large area.
3. Broom Finish
Broom finishes provide texture by simply sweeping a broom across the surface of wet concrete. With this type of finish, one of the big advantages is simplicity. You will not have to spend a lot of time doing this project because you only have to take a broom across the top of the concrete. Another advantage of using a broom finish is that it is less expensive than other finishing techniques. You do not have to buy any stencils or expensive equipment.
The disadvantage of this strategy is that it is fairly plain. You do not get any noticeable designs or patterns that create a visually interesting element.
 forum activity
