3 Things to Know When Building a Portable Cool Mist Humidifier
When building a portable cool mist humidifier, there are several things to keep in mind. A cool mist humidifier will add moisture into the air of a room by saturating the air with water. It is possible to build your own cool mist humidifier to help saturate and moisturize the air in your home. When building your own portable humidifier, use these tips to help your project be successful.
Tip 1 – Test Humidity
To ensure your humidifier is functioning properly, you should test your air with a humidity monitor. This monitor will test the humidity of the air and give you a reliable reading that will show if your humidifier is functioning adequately.
Tip 2 – Size
You will need to remember to keep the size of the humidifier small and compact. This will increase the portability of the unit and make it safer by preventing accidental damage to the unit.
Tip 3 – Vapor Direction
Pay attention to the direction of the vapor from your unit. The best directionality of the vapor from a cool mist humidifier is angled upward. You should not have the vapor directed directly above the unit as the falling moisture could damage the unit over time. By directing the vapor at an angle, you prevent unit damage and create the best direction for output.
