3 Tips for Cleaning a Stainless Steel Countertop
Stainless steel countertop is a feature found in most houses today. Stainless steel is chosen by a lot of people because it looks modern and sophisticated. Stainless steel is also not difficult to clean at all. You do not have to worry about spilling oils or acids on it. Let us look at some tips on how to maintain stainless steel so that it will not be subject to rusting or corrosion.
Tip 1: Dry Cleaning Stainless Steel Countertops
If you are dry cleaning your countertop, all you need is a microfiber cloth that you can wipe it with. Do this whenever you do wet cleaning or get the countertop wet so that you do not encounter water stains on it.
Tip 2: Wet Cleaning Stainless Steel Countertops
Wet cleaning the countertop involves the use of a dishwashing liquid that is mild enough for the steel. Harsh ones can cause staining.
Tip 3: Dealing with Tougher Stains
You can find abrasives that are made specifically for stainless steel surfaces. These are for the tougher stains that you might encounter. You can also use these cleansers for removing smudges and fingerprints. If you need to do some scratching out because the stain is too tough, or because you have scratched on the surface, use only a nylon scouring pad. Do the scrubbing slowly.
