Login Error
Close
3 Tips for Cleaning Hardwood Floors after Sanding
by DoItYourself Staff
The task of cleaning hardwood floors after sanding can be a time consuming one. Here are a few tips that can help make the process go by smoothly.
Tip 1 - Use a Vacuum
The first thing that you will want to do is use a vacuum to get rid of any dust that you can. Begin by sweeping as much as you can into a pile and then vacuum up that portion.
Tip 2 - Use a Damp Rag
The best way to get the left over dust off is to use a damp rag or a swifter. All you need to do is wipe in one direction and then use the rag to lift the dust off of the hardwood floors. It helps to have a garbage or laundry basket near by for disposal.
Tip 3 - Use a Wood Cleaner
Finally, after you have removed all of the dust from sanding, you can use a wood cleaner to polish the floor. Use a new, soft rag with cleaner sprayed on it. Gently clean the floor in a circular motion.
Following these 3 tips in this order will ensure that you remove all of the dust from the area and that you hardwood floors will look great.
 forum activity
