3 Tips for Cutting an Aluminum Pipe
An aluminum pipe can be used in many areas of the home and in crafting endeavors. Aluminum is a soft metal that's very touchy when working with it. If you're trying to weld an aluminum pipe, for instance, you may run the risk of burning a hole through it and melting it. It's the softness that makes cutting aluminum pipe equally difficult as welding it. Cutting it the wrong way can cause shards or aluminum to go flying, which can become embedded in your skin or eyes. It's also very easy to crimp the aluminum pipe at the area where you intend to cut it. The information below is a short guide on what you can do to cut the aluminum pipe without damaging it.
1. The Right Cutting Tool
Doing any type of work around the home or your job always requires the right tool. You would not use a hammer to remove screws from a wooden fence. This also applies to cutting aluminum pipe. You can cut the pipe with several tools, including a hacksaw, a circular saw or a pipe cutter. A hacksaw is all muscle driven and usually not the choice tool to cut a pipe. Aluminum pipe, however, is weaker than other metals, which make a hacksaw usable. A circular saw is a great tool to use to cut aluminum pipe because you can get saw blades made specifically for this job. A pipe cutter is a tool that is only used to cut pipe. You essentially place the pipe in the reservoir and turn the cutter. It cuts around the diameter of the pipe, which prevents bending and shards from forming.
2. Lubrication
Regardless of which tool you choose to use to cut the pipe, you will always need to lubricate the pipe. The lubrication is also for the saw because cutting metal can easily damage the blade. As you cut, you generate friction, which causes heat, and this can cause a blade to break. There are cutting tool lubrication products on the market that you can use, but you can save some money and use wax instead. An old candle is perfect lubricating product that will help the blade and the aluminum pipe. Wet cutting is also an option. Have a hose or use a wet saw with a metal cutting blade attached. It will keep the pipe and blade cool.
3. Slow Down
Cutting aluminum pipe is sometimes trial and error, but it can easily be done without any mishaps. One of the biggest problems you will face is making sure that the pipe does not bend or crimp as your cutting it. This is very common because aluminum is very pliable. In order to prevent this from happening, you should slow down as you reach the end of the cut. Slowing down reduces the pressure placed on the pipe, which prevents it from bending. This is especially important when using a hacksaw to cut the pipe and is not an issue when using a pipe cutter.
