Login Error
Close
3 Tips for Cutting Vinyl Flooring
by DoItYourself Staff
Vinyl flooring is not a difficult material to work with and you can achieve fantastic results even if you are fairly new at the task. Thus you can have a cost effective project and you can recreate the interior of a room in your house without getting the help of a professional. Be careful though as you will be using sharp instruments in cutting through the material.
Measuring the Area Accurately
In working with vinyl flooring, always have in mind the old adage of measuring twice and cutting once. There will always be odd shapes that you will encounter on the rooms of your house. The reasons could be a misaligned wall or there is trimming is installed that is oddly shaped. No matter what the reasons are, never assume that you will be dealing with square measurements all the time. If you are working on tiles, you will not have much of a problem with measurement until you get on the edges or around structures. In such a case, the best way of doing a measurement is with a couple of tiles and a pencil. Put one tile as squarely as possible to the other and push it up on the obstruction or angle. You can then lay over it the other tile use the pencil to mark the line. If you are working with rolls, cut more than what is needed slightly and put the sheet down on the floor. Keep it down with bricks or other heavy object and push down on the roll until it meets up with the floor edge. Mark the top of the sheet as near to the wall edge as possible.
Using Heat Safely in Cutting
You can cut vinyl flooring without using heat but it would be easier to cut clean and straight with a heated vinyl. Some people use a heat gun while others use a soldering torch. You can even use an ordinary hair dryer. But no matter what technique you use, always be careful when you are using fire. Heat the area you are going to cut by going over it back and forth. Holding it too close will damage the vinyl. If you hold it on one place for too long, you are going to discolor the material. Use brisk action to move the heater back and forth until you have made the vinyl more flexible. If torch is used, always make sure that no hair, loose clothing or anything flammable is on or near the vinyl.
Cutting the Material
Vinyl flooring can be cut by means of a utility knife pulled slowly across the top. If you notice that the material is starting to be harder, reheat it. Always make sure that you cut less than what you are supposed to remove. If you overcut, there will be gaps on the area where you are going to lay the material. It is better to trim off some extra than to remove too much of the vinyl. Make it a point not to cut towards you. If you do so and the knife slips, you are going to cut yourself badly.
 forum activity
