Login Error
Close
3 Tips for Fixing a Broken HDMI Cable
by DoItYourself Staff
what you'll need
  • Replacement HDMI Cable
  • Wire Cutters
  • Electricians Tape
HDMI cable is used to connect a high definition multimedia interface receiver to your television set. The cable is designed to unscramble the signal sent by the high definition multimedia receiver in order for you to get a clear picture.
If the high definition multimedia interface receiver’s cable is broken, you should purchase a replacement cable. If the receiver was provided by a local cable or satellite company, you can request that one of their technicians brings you a replacement cable. You can attempt to repair the cable yourself but may find that the way to repair the cable is to replace it.
Step 1: Troubleshoot Problem with the HDMI Cable
You will need to determine the problem with the high definition multimedia interface cable in order to know what needs to be fixed. The common problem that causes the cable to be broken is an interruption in the wiring at the high definition multimedia interface cable’s connector that causes the signal to be fuzzy or broken. This problem can result over time as the cable gets older, or if it is crimped.
If the problem is that the picture to your television set is unclear, you may be able to replace the connector in order to fix the high definition multimedia interface cable.
Step 2: Cut the Connector
Unplug the high definition multimedia interface cable from the DHMI receiver. Take a pair of wire cutters and cut the connector off at the tip of the cable leaving yourself some room to work with in order to splice a new connector on. You will need to obtain a replacement cable connector for the high definition multimedia interface cable. You can go to an electronics store or use an old cable that is not being used by the receiver.
The old high definition multimedia interface cable that you use should have a good connector that can be salvaged. You can use an electrical current tester to determine if the connector is still viable for use with the broken high definition multimedia interface cable. If it is not any good, go to an electronics parts store to purchase a new connector for your high definition multimedia interface cable.
Step 3: Splice the New Connector onto the HDMI Cable
Take the replacement connector for the high definition multimedia interface cable and connect it, splicing the wires together. Be sure to match the corresponding wires carefully because any interruption will cause the signal to appear damaged when you plug the high definition multimedia interface receiver in and turn the television set on. Use the electricians tape to cover the exposed wiring before moving to the final step in this repair process.
Step 4: Connect the Cable to the HDMI Receiver
Once you have completed the repair of the broken high definition multimedia interface cable, connect the cable to the high definition multimedia interface receiver. Turn the television set on and check the picture quality to make sure that the problems identified in Step 1 of this article have gone away.
 forum activity
