Login Error
Close
3 Tips for Installing a Corner Shower Rod
by DoItYourself Staff
If you have a shower in your bathroom that is installed in a corner, then you need to install a corner shower rod. Having enough conveniences in your bathroom is essential since the room provides a place for relaxation in the house, as well as a place for a temporary break. This is the reason why it is essential that you look at anything in it that needs to be improved. If a normal curtain rod that is straight is used in a corner, the effect would be to force you deeper into the corner and make the restrictive space more uncomfortable and smaller. The resulting triangular shape would also not look good in a bathroom. It will not be able to match with anything else and puts the general design of the bathroom off.
Using the Appropriate Shower Rod
There is a solution that you can use for a corner shower rod and that is a rod that has been bent into a 90 degree angle. This will allow you to install it on the adjoining shower walls. Because the resulting shape is in the form of a square, you will be able to have more space in your shower enclosure. There will be no curtain that will push you into the corner and make you feel uncomfortable. The square shape will also make your bathroom appear better so the bent shower rod can add to the beauty of your bathroom as well.
Considering the Material of Your Shower Rod
As with other types of shower rods, it is essential that you consider the kind of material that is used in the making of a corner shower rod. This will allow you to put the details and style of your bathroom in better perspective. Have a look at the other fixtures in your bathroom as well as the tiles, sink and toilet. Consider how you can make the material and color of your shower rod fit better with the rest of your bathroom. Among the materials that you can choose from are iron, bronze and steel. There are other materials that are available so you should not run out of options. You should also consider if the measurement of the shower rod will fit the dimensions of your bathroom. Hence, you should take the measurement of your shower area first, before purchasing a shower rod.
Installing Your Corner Shower Rod
Before you install your corner shower rod, put markings on the wall first to know where the screws should go and then attach the studs to them. The shower rod should be screwed on to these studs. This will allow the shower rod to be secured better. Your next task should be the attachment of the clips that will be used for hanging the curtains up. The right length of curtain should be one that is barely touching the floor.
You should also determine how high you want your curtain to be and purchase your curtains accordingly. This will prevent you from having a curtain that is too long and a slip hazard.
 forum activity
