Login Error
Close
3 Tips for Panoramic Photos
by DoItYourself Staff
Panoramic photos give a sense of a wide range of images in a single photo. With most cameras, you capture a still image that is within the range of the lens. In another words, the image that is right in front of you. With a panoramic photo, however, the viewer sees not only the image that is in front of the lens, but also those images that are to the left and right of the lens. Panoramic photos lets you show the full effect of the surrounding involved in the picture. It can be a great way to remember special vacations and places of interest that are lost without the full display of a panoramic image.
There are cameras that specialize in panoramic photos. As you can guess, however, they are expensive and typically only used by professional photographers or individuals who are serious hobbyists. Nonetheless, there are ways that you can create the appearance of a panoramic photo using a regular telephoto camera. This includes using a manual camera setting and focus, using a normal or tele lenses, and investing in software that can join photos to create a panoramic view. Below are some tips for creating panoramic photos from the pictures that you take.
Using the Manual Mode and Focus
Set the camera to the manual mode when taking panoramic view photos. Automatic settings will adjust the color settings and contrast, making it harder to match shots when creating a panoramic photo. The same goes for the focus. It should be set to manual in order to keep the camera from picking out a focal point that throws your panoramic look off.
Using  a Normal or Tele Lens
Using a normal or tele lens with zoom will give you the narrowest view of the panoramic shot. Wide angle lenses should not be used when taking panoramic photos because it may include too many elements in the picture, making it harder to stitch the photos together to make the panoramic photo.
Purchase a 18 – 55 mm lens and use a setting between 50 – 55 mm, which is ideal for taking panoramic pictures. This will help you create the best panoramic photographs.
Using Software to Join Photos
The final tip for taking panoramic photos is to use photo stitching software that joins sequential pictures. The software will join the photos together and create the panoramic effect that you seek.
Some places, like a pharmacy photo developing kiosk or ones available at a print and copy center, also offer a way for you to select pictures and create panoramic photo prints. You can use the services of these facilities instead of buying software. You may, however, want the convenience of working on creating panoramic photos in the comfort of your own home, so buying the software may be a better move.
 forum activity
