Login Error
Close
3 Tips for Reducing Radiator Cap Pressure in Hot Weather
by DoItYourself Staff
Radiator cap pressure is something that you will have to keep an eye on to ensure that your car is not going to overheat. Hot weather is the best time for your car to overheat if it is having any problems with the radiator. You will find that the more you are able to reduce the pressure for the radiator cap the better off your car will be when it comes to being safe from overheating. Every time that your car overheats, it does quite a bit of damage to the inner workings of your vehicle. That is why prevention is so important.
Tip 1 - Causes of Overheating
Understanding the causes of overheating will help you to be able to prevent it later down the road. You will always need to keep your car in contact with a cooler liquid. The best way to do this is with coolant. The coolant needs to be able to get rid of the heat that is absorbed. A cooling fan is needed for this job to keep the air circulating. Circulating air is the best way to keep the pressure down and off your cap so that your car will be able to run smoothly. Basically, overheating is caused by anything that can make the cooling system unable to absorb and transport the heat that is constantly circulating through your car.
Tip 2 - Coolant
Coolant is the most important thing to keep in mind with your car. This is especially true whenever you are driving it in hot temperatures. Your car will need to have a way to get rid of the heat more than ever whenever it is surrounded by hot temperatures. The best way to do this is to check the coolant frequently. Keep it at levels that are recommended and always keep an eye out for leaks. If there is a green liquid that is leaking out of your car then you will need to try to not drive it until you are able to get the leak fixed. This is especially true in hot weather as any loss in coolant could be devastating to your car.
Tip 3 - Drive Carefully
Whenever you are driving your car in the heat you will need to remember that your car needs extra care. You should not drive your car too heavily or hard whenever it is hot outside. Do not immediately turn your air conditioner on high as soon as your start your car. If your car is going to be stopped for a long period of time, turn the air conditioner off or down. Do not allow your car to run for long periods of time if it can be helped. If you are running into the store then turn your car off. Allowing your car to run in the heat will cause it extra pressure to be put on your radiator cap this, in turn could cause it to overheat.
It is important to pay extra attention to your car whenever it is excessively hot outside. No matter how good of shape your car is in, abusing it in the heat could do irreversible damage.
 forum activity
