3 Tips for Using Mastic Tile
Mastic tile is simple to work with and it is inexpensive. It's commonly used for small tiles on walls or counter tops. There are several ways to work with mastic to get the most out of it. Here are a few tips that can help you out.
1. Work in Dry Areas
In order for mastic to adhere properly the area needs to be completely dry. If you are working with sub-flooring, you should seal it first to avoid moisture from building up above the flooring as you are working.
2. Grouting and Sealing
When mastic is used in areas that are prone to occasional moisture issues, using a proper sealant will help keep joints in tact. Make sure to use proper grouting to help keep moisture from building under the tile.
3. Application
Mastic is typically pre-mixed, making it an ideal choice for any novice. It's easier to apply when using a notched trowel and working in horizontal lines. This will help support the tiles against the wall using gravity as it dries. It shouldn't be applied to thickly, or used to build up uneven surfaces. This can cause the tiles to crack and pop later.
