Login Error
Close
3 Tips for Water Cistern Repair
by DoItYourself Staff
A water cistern repair may be necessary if it is leaking or not working properly. A water cistern is a type of device used to catch and remove water. The typical type of material that is used in a water cistern is concrete. If the water cistern is in need of repair you need to do some troubleshooting to determine where the problem lies and how it can be fixed. You can also repair the spots in the concrete that may be the source of the leak as a way to fix the water cistern. You may also need to replace the water cistern in order to repair it.
These tips are a few of the suggestions that can help you address any problem that you have with your water cistern. These tips are based on a common sense approach to identifying, addressing or replacing your water cistern in order to return it to its proper function. This article will explore these tips in more detail and provide you with a way to approach a water cistern repair that will result in the elimination of the problem and make you satisfied with the use of the water cistern.
Troubleshooting the Water Cistern Repair
The first tip relative to a water cistern is troubleshooting the problem in order to determine where the problem lies and why it is not working properly. The troubleshooting process involves determining where the problem lies that is causing it not to work and assessing the steps needed to solve the problem. The problems that may arise causing your water cistern not to work correctly can include leaking, improper connections with the pipes, cogs and clots in the drainage system among other problems that you can potentially identify. The troubleshooting process can help you pinpoint those areas where repairs are needed and provide you with a way to determine the best solution.
Plugging a Leaking Water Cistern
A leaking water cistern may result from holes or cracks in the concrete. This problem can be identified easily during the troubleshooting stage and addressed by applying a patch to the concrete where the leak has developed. This will help fix the problem of a leaking concrete water cistern. A patch can be done quickly and easily in the same manner that any other concrete repair is done around the home.
Replacing the Water Cistern
After troubleshooting and plugging the water cistern you may also need to consider whether or not the water cistern needs to be replaced. If all of your repair attempts to address what the problem may be, you need to think about replacing the system with a new one. Make this determination based on the age of the water cistern, the extent of the problems that you uncovered during the troubleshooting and whether the repairs that were attempted were successful. In some cases this may be the only option available for your repair.
 forum activity
