Login Error
Close
3 Tips to Use a Solution of Bleach for Cleaning Mold
by DoItYourself Staff
Mold is a pestilent fungus that’s both harmful and undesirable; and if you have it in your bathroom you might as well reach for that powerful solution bleach. Mold spores can cause respiratory problems such as asthma, so it’s no wonder that when cleaning a bathroom most people want to do a thorough job of removing it and killing any traces that remain. Since bleach is a substance we trust in bathrooms to kill germs in our toilets and on our surfaces, it seems to make perfect sense to use it on mold infestations. The true effectiveness of bleach in killing mold is often a matter of debate. However, it is a good method of cleaning if you use it well. Bleach has sanitizing properties that reacts against mold, which is certain. There are some ways of including it in your cleaning process that will effectively combat mold and encourage it to stay away in future.
Tip 1 – Use Bleach Only on Surfaces where it will Be Effective
Bleach will not remove mold from surfaces that are metallic, porous or excessively dirty. This will ensure your efforts are effective. Be mindful of the fact that porous or metallic surfaces with a mold infestation will need to be cleaned with something besides bleach. Other features of a bathroom that you won’t be able to remove mold from with bleach are rugs and carpets. Think about removing these from a bathroom all together if you want to stay free from mold.
Tip 2 – Use a Strong Bleach Solution on Mold
Where mold is concerned, you shouldn’t be too sparing with the amount of bleach you add to water for a cleaning solution. Use an entire cup of bleach mixed with a gallon of water for good results. This powerful solution needs to be sprayed onto an area of mold that’s free of dirt and grime and left there for 30 minutes. With a strong bleach solution of this kind, you need to take necessary safety precautions such as wearing gloves, and avoiding any contact with skin, eyes or hair. You should also wear a mask and use a ventilator when dealing with mold, as the spores can really be hazardous.
Tip 3 – Use a Wire Brush
Using a wire brush in conjunction with a bleach and water solution to remove mold is a very good idea. Allow the bleach solution to act on the mold before you start scrubbing. Put plenty of effort into the manual labor when you do scrub. Be methodical in your approach so that all of the affected area is covered, and work in a circular motion. Rinse to see where you’re up to after some time and repeat the process with as much vigor as you used the first time round. Remember that while there may appear to be no trace of mold on the surface you’re cleaning, some spores can still remain. Do a thorough job to ensure that it doesn’t start growing again soon after you’ve finished.
 forum activity
