Login Error
Close
3 Types of Roof Shingles
by DoItYourself Staff
Understanding a little bit about the different roof shingles types can provide you with the information that you need to know before choosing what material that you want for your house. Every type of shingle is going to have some benefits and some drawbacks. Here are a few of the more popular types of roof shingles on the market.
1. Asphalt
Asphalt shingles are the most commonly used roofing material in the world today. You will find asphalt shingles on roofs in every part of the country. They are commonly used because they are very cost-effective. This is going to be the least expensive option that you have in most cases. Asphalt will also give you some decent durability and will last for as long as 30 years in some cases. Since much people are not going to be in their homes for longer than 30 years, asphalt makes a lot of sense as an investment. They are also very easy to install. When you install asphalt shingles, you can simply nail them into the roof. They are somewhat heavy, but they are a lot lighter than some of the other options that you have. You are not going to have to worry about as many structural issues as you would with heavier roofing materials.
2. Wood Shingles
Wood shingles are another commonly used roofing material. There are many different species of wood that you can use for shingle material. Cedar is one of the most commonly used species of wood for this application. Pine is another species that is frequently used to make shingles out of. Both of them look great and they can be very durable if installed correctly. When you use wood shingles, you want to make sure that you are buying a quality product. They need to be thoroughly sealed up so that they can hold up to moisture. One of the drawbacks of wood shingles is that they can fade in the sunlight over a certain period of time. Wood shingles are also very simple to install. You can typically nail them in place.
3. Slate Shingles
Slate shingles are another popular variation of roofing material. Slate shingles are most commonly used in high-end applications. They have a very elegant look and many people prefer them when they have a nice house. Slate shingles are extremely durable when compared to other materials that you can buy. In many cases, you will be able to have your slate shingles on the roof for 50 to 75 years without any issues.
Even though they are durable, they have a few drawbacks that you will need to know about. First of all, these shingles are very expensive. You are going to have to pay much more for these shingles than you would with asphalt or wood shingles. Another potential drawback is that they are extremely heavy. You have to make sure that your roof can support the amount of weight that they will have.
 forum activity
