Login Error
Close
3 Ways to Improve Oil Furnace Efficiency
by DoItYourself Staff
If you've been looking to improve your home's oil furnace efficiency, there are a number of ways you can go about completing this task. Read on to learn everything you'll need to know about making your oil furnace more efficient.
Regular Maintenance
Regular maintenance is arguably the most important factor in improving oil furnace efficiency. All oil furnaces should be thoroughly cleaned, tested and tuned annually, although if you live in a cooler climate, it might be a good idea to clean your furnace on a somewhat more frequent basis. This process will typically entail brushing and vacuuming your oil furnace's heat exchanger and purging any accumulated soot. If left unchecked, soot buildup can dramatically decrease your furnace's performance quality and, by extension, the overall air quality of your home. It should be noted that unless you have experience working with furnaces, you may want to incorporate the aid of a certified furnace technician for all matters maintenance related.
Regular Maintenance
Another good way to improve your oil furnace's efficiency is to replace certain components on a regular basis. Your furnace's oil filter, for example, will need to be replaced at least once a year. Furthermore, your furnace's oil spray nozzle will also need to be replaced annually. When replacing these parts, always make a point of choosing the most cost effective and energy efficient brands available. While it may seem cumbersome, annually replacing these components is a great way to ensure that your oil furnace runs safely and efficiently.
Before committing to buy, go online and find consumer testimonials from people who own the same brand and model of furnace as you. This will help you determine the best types of parts to use with your furnace. Once again, unless furnaces are devices with which you have a great deal of experience, it is recommended that you outsource the installation of your replacement parts to a certified furnace technician.
Thermostat Control
Although it may seem obvious, turning down your thermostat at various points throughout the day is another easy way to improve oil furnace efficiency. If you work outside the home, make a point of lowering your thermostat five to ten degrees during your daily absence. To that end, you may want to consider lowering the thermostat whenever your home is unoccupied. Many people chose to lower their thermostat at night when their families are asleep. Some oil furnaces come with thermostats that feature an automatic setback option, which enables you to preselect the specific times at which you would like the temperature reduced, as well as how much you would like it reduced.
In addition to making sure your oil furnace isn't overtaxed, thermostat control is a great way to save on heating costs, particularly during the winter months. Be advised, however, that if small children or elderly relatives are among your home's residents, it may be unwise to make any sudden dramatic changes in your house's temperature.
 forum activity
