Login Error
Close
4 Advantages of Using a Mini Split Heat Pump
by DoItYourself Staff
A mini-split heat pump is an attempt to hybrid the outdoor air-source unit with a large number of indoor units which then provide heat to water radiators or space heaters. These, and the ductless mini split systems are both a good way of fitting a home with the best kind of pump system, as you have the flexibility of a heating system with a fixed source which is much greener than the traditional HVAC units. The air devices for the mini split can be fitted through the walls, ceilings and floors and are small enough to be placed just about anywhere.
1 - Advantages to the Mini Split
The mini-split is probably one of the most user-friendly systems which can be managed in a private home without costing a very large amount. While the price is rather greater than the standard HVAC systems, you have to take in the consideration that all of your items will save you money in the future costs of heating in the room. You may have the price of the initial layout and installation to pay for, but you will get several hundred dollars from savings from your energy bill each year.
Environmentally Friendly
There are a number of advantages to using the mini-split system, including the benefits of combining the flexibility of an indoor ductless heating system with the power of an environmentally friendly system. The air source heat pump can provide a lot of the heat which could be traditionally provided by the electrical or gas units, and the mini-split heat pump will also benefit the heating bill, as you can get around 40% less than the average bill of a modern American home. If you want to do the best for your system, then the mini-split will allow you to have the advantages of both indoor and outdoor power supplies.
Convenience of Use
The mini-split system can provide heat to a number of several rooms of the house, and the little heaters which bring the warmth to the room can easily be placed around the room, depending upon the number of places that you want to heat at once. You could also place on one of the supporting ducts into the space between 2 walls, so you could transfer the heating between each of these areas easily.
Flexibility
The flexibility is the best of the heat pumps which use an outside source. This is perhaps due to the small size of the air devices means that you will be able to place them in a variety of places, depending upon which will fit into he different rooms of the house. If you are interested in the mini-split heat pump, you should also consider the ductless, which combines some of the advantages of the split system with that of a ductless AC unit, making it even more flexible in its creation.
 forum activity
