Login Error
Close
4 Advantages of Using Fluorescent Garage Lighting
by DoItYourself Staff
There are many advantages to using florescent garage lighting, both inside and outside of the garage itself. You can use garage lights to help keep the drive well lit, or you may wish to use it for illuminating the interior, but whichever type of illumination you need, using a florescent light is one of the best choices that you can make. Florescent lighting is a traditional method of lighting areas of the house that need bright, steady light, but do not have the space to have a series of lights, for example in the kitchen. The reasons for choosing florescent garage lighting above all else makes the best use of your available space.
Cost
The cost of florescent lighting is perhaps one of the most common reasons why they are used. Florescent lighting is very cheap compared with other sources of lighting, such as the halogen. In addition to the first fitting being cost-effective, the replacement bulbs are also cheaper than the alternatives, so you won't be out of pocket by using these types of light.
Availability
Florescent lights are very common, and are available in most home improvement stores, and even some supermarkets, so you will never have to wait for a florescent light to come from a single supplier. For these reasons, florescent garage lighting is good if you need a daily supply of light to the garage.
Effectiveness
In addition, the florescent light is advantageous because of the strength of its light. If you want a bright, powerful light, you should pick the florescent bulb. For those working in a garage, for example using a workbench, or running a small business from this area of your home, then you will need a strong and secure light. Despite this consistent, bright light, the bulb is very efficient, and uses a limited supply of electricity. This is a good saving to make if you use the garage area regularly. In this instance, they are more likely to be energy efficient than a halogen bulb, which is only suitable for short bursts of light. Many green designers are now coming to use florescent lighting much more in their home planning, as they can be turned into long-life lights, which do not need to be replaced so often.
Practicality
Florescent lights are perhaps the most practical devices which are available for use by the general public, at least where garage lighting is concerned. Florescent garage lights can be bought with fittings that have the switch connected to the light, so that you can easily turn it on and off. This would make it suitable for those who want to turn on a bright light over the garage doors, perhaps when arriving home late at night, or starting out early in the morning, before it gets light. They are quick to come on, so you don't have to wait for very long before it illuminates the area.
 forum activity
