4 Advantages of Using Thin Film Solar Panels
Thin film solar panels are made by placing very thin layers of a photosensitive or photovoltaic material on top of each other. There is a wide range of different sizes in these solar panel layers, but they are all classed as thin film solar panels. If you are considering using solar devices to heat or power your home, there are many reasons why you should get these types of panels over the more traditional, thick types which are more familiar to the general public. When looking for a thin film solar panel system, you should consider the costs, the energy efficiency, and the production standards of the models available to you.
1. Cost
One of the most attractive reasons for purchasing the thin film solar panels is the cost of your devices. In recent years, this type of solar panel has become more popular, and demand has grown. At the same time, manufacturers have become aware that the cost of most solar panels is prohibitive to the general public, and as a result, they have been working to reduce costs. Goals set by the manufacturers suggest that they could start to be under $50 per square meter, which would provide a very cost-effective method of using solar panels in your home, particularly compared with the silicone cell which will remain at around $100 to 200 per square meter.
2. Portability
One of the ways in which thin film solar panels are frequently used is as a portable heating device for shavers, hot water showers, and as a non-conventional power source. Thin film panels can be rolled up, much like sleeping bags, and this makes them easily transported. Roll-up solar panels are a big advantage if you enjoy camping or hiking, as they are lightweight and easily moved. If you are looking for a way to use solar energy in your camping or caravan holiday, then these thin film panels are the perfect solution.
3. Use
Thin solar panels are ideal for use in a number of applications, including as solar tiles and as roof shingles. As they are so thin, they are more malleable, and therefore can be manipulated into the shapes of tiles. They can also be used where space is at a premium, as the panel can be rolled away when the sun is behind clouds, or their energy source is not required.
4. Energy Efficiency
The thinness of the layers often means that the panels don't pick up so much energy as the thicker bulk silicon devices. This is not a big problem when they are being used to power small items, for example when they are powering shavers, hot water tanks for small households, or other places where a little energy is all that is needed. Thin film is actually better used during low light, particularly in shaded areas, meaning that they can work better than the larger solar panel cells. As they are capable of being used in large quantities, and very cheaply, their numbers can make up for individual lack of energy efficiency.
