4 Attic Storage Container Insulation Tips
If you are looking at different types of attic storage, you will need to insulate your containers to withstand any temperature changes and potential moisture that may get trapped within the attic. Below are some insulation tips to consider.
Tip 1 - Use Plastic
Plastic has but in insulation because it is strong and easily susceptible to weathering. You can also use clear plastic in your attic, which will help you see what is in each container.
Tip 2 - Line with Old Blankets
If you have a bunch of old blankets you were looking to store anyways, consider lining your storage containers with them. That will help provide an extra layer of padding for your items, and it will decrease the chances of the items being affected by temperature changes.
Tip 3 - Caulk the Cracks
If you are using wooden storage containers or any containers that may have cracks in them, consider caulking over the cracks to provide an extra layer of sealant on the outside. If water seeps in from the roof, you will be thankful for the caulk.
Tip 4 - Use Packing Peanuts
If you aren't going to be using the contents of your container for a long time, consider putting packing peanuts in there for insulation. They will fill all the gaps for you.
