4 Bathroom Paint Ideas for Your Home
Bathroom paint ideas can be as creative and imaginative as you so desire. If you are considering painting your bathroom and need a few ideas to get started, consider the below ideas for a little inspiration.
Paint with Sponges
You can get a really airy and comforting look using some simple sponge painting techniques. For a beach theme, try sponging bright yellow paint towards the top of the walls and use other yellows to gradually fade into a dark sand color at the bottom. Overall, sponge painting using a couple colors will add some vibrancy to your bathroom, but won't be too overpowering for the room.
Consider Dark Colors
Don’t be afraid of using darker colors, such as black. You can create a very modern look with a simple chair rail, black paint, and a splash of a neutral color. Additionally, adding a couple colorful items, like artwork or a artificial plant, will compliment the black paint of the bathroom.
Try a Glaze
If you're bathroom is traditional in style, glazing is a great option for the walls. Glazing gives your walls a bit of extra color and texture. If you decide to use this technique, make sure you allocate enough time to properly apply the glaze to your walls.
Make Use of Stencils
Stencils are quite a bit easier to paint than applying a wallpaper border. You also have the opportunity to customize your color scheme. Additionally, you can mix and match the stencils for additional customization and design for your bathroom.
