4 Benefits of Owning a Solar Pool Cover
A solar pool cover is a tool that you can use to heat the pool in your backyard. You can buy a solar pool cover for an inground pool as well as an above ground pool. The purpose of owning and using a solar pool cover is to use the sun to heat the water. These large vinyl covers typically have solar collectors woven within the vinyl that collect and then redirect the solar rays from the sun. There are many things to consider when you buy a solar pool cover. The following article will provide you with several of the benefits that go with owning and using a solar pool cover.
1. Durability
There are many types of pool covers you can purchase but not all of them are not going to stand up to the brutality of the elements. A solar pool cover is designed to be thicker than other covers. They are also somewhat lighter than traditional covers meant to simply protect the water from ice and bugs. The solar pool cover has to be made this way so that the sun’s energy is able to be collected and stored and then redirected.
2. Reduced Pool Heating Costs
If you want a heated pool then you will either have to build a black tube system or pick up a pool heater. A solar pool cover does not actually heat a pool but prevents heat from escaping. The pool’s water absorbs about 75 to 85-percent of the sun’s energy. This heat escapes the pool quickly. The solar pool cover prevents this heat from escaping. This is also the case if you have a pool heater installed which will save you expensive heating costs.
3. Environmentally Safe
Solar energy is an incredibly clean energy which will not damage the environment, your pool or create any type of emissions. This cannot be said about pool heaters which require regular maintenance, draw power from the grid and can produce emissions. A solar pool cover is simply insulated and it is this special insulation which allows them to effectively trap in the heat. When you remove the cover the heating conservation stops but the water will maintain the heat until that time.
4. Pool Protection
The inside of your pool is actually very delicate. When your pool is not properly covered then leaves, bugs, small animals and other debris can find their way inside. These bits of debris will get sucked in to the filter system and will cause damage to it. The liner of the pool can also fade and crack if the sun is allowed to beat down on it day after day. A normal pool cover will protect the inside the pool but using a solar pool cover will do that while maintaining the temperature. Being able to maintain the temperature can also help to prevent the growth of mold and mildew. When the temperatures fluctuate too much inside the pool the ideal conditions for mold and mildew growth can be reached.
