4 Best Performing Residential Electrical Wiring Devices
As you consider updating the electrical wiring devices in your home, you should start a short list of things that will make your life easier in your home. Many of the updated devices in the marketplace will help to save you energy and money each and every month. Some of the new devices are available for wireless installation and utilization and other devices are just good to have household components. Below is a list of four best performing and convenient electrical wiring devices every homeowner should consider purchasing and using in their residential applications.
1 - Dimmer Switches
During your updates to your electrical components in your home, consider purchasing dimmer switches and changing around the conventional switches you have installed. Some of the new styles of dimmer switches light up with a background LED display. When you use a dimmer switch with your lighting, you will save anywhere from 10 and 15% in your energy costs and you will extend the life of your lightbulbs. An average dimmer switch will cost about $30.
2 - Fan Speed Controls
Fans help to cool a room and recirculate the air. They are almost an essential component of every room but it is often unnecessary to have the fan run at full speed all the time. In order to have the ability to adjust the fan speed, you will need to add a few fan speed controls. There are different types of fan speed controls that you can purchase. You can purchase and install a fan speed control that replaces your current wall switch or you can purchase and install a wireless remote control system. The wireless system is a great addition to any smart home or structured wiring system design.
3 - Digital in the Wall Timers
These little electrical wiring devices are becoming very popular in today's home. The digital in the wall timer replaces a standard wall switch. It gives you an ability to automatically control the inside and outside lighting of your home. In addition to giving you the ability to control the lighting, you can use this timer to control fans, pumps, office components and other systems or components. They are decorative and will add to any different decor.
4 - Add a Generator
A generator is something that you probably do not think about when you are looking at updating your wiring devices, but it is something you should not overlook. A generator used in the home can protect several of your appliances from failure during an electrical or wind storm. You will never have to deal with spoiled food ever again. They are easy to install and connect to your wiring in your home. Some of the generators can be installed in the basement and others sit nicely outdoors next to the exterior of the home.
Enjoy your updated wiring devices in your home each and every day.
