Login Error
Close
4 Best Pet Odor Removal Options for Linoleum or Marble Floors
by DoItYourself Staff
People who have pets are always on the lookout for a per odor eliminator. When it comes to floors, the biggest trouble is removing the smell of urine or feces. No matter how well-trained a pet, there are times when it may not have total control over itself, resulting in an accident. While the accidents can be easily cleaned up, the foul smell is not very easy to take care of. What’s worse is that if you are not able to remove the smell of urine or feces completely from the floor, it can eventually become your pet’s designated relieving area inside the house.
Getting Rid of Odor
To prevent any area of your house from becoming a designated toilet for your pet, you need to clean the area completely so that absolutely no smell lingers. Here are 4 of the best pet odor removal options.
  1. Chemicals and Sprays
No matter what kind of accident your pet has had, there are chemicals and sprays available on the market to get rid if these. Use a pet accident wash up solution to get rid of the odor of urine, feces or vomit from the floor. You can also use citrus concentrate on the area where the odor is the most obvious. Let the solution stand for a few minutes before cleaning it up with a mop.
  1. Boric Acid
Make a paste of boric acid with water. Coat the area that your pet has soiled with this paste and allow it to stand for a few minutes. Once the acid paste has been standing for a few minutes, use a scrub brush to scrub it out, and then clean up the residue with water and a sponge.
  1. Straight Bleach
Use straight bleach to clean your floor. While straight bleach can quickly douse any foul odor that may be coming from your tiles, it is not advisable to let it stand for long as it can cause damage to your flooring. The best way to use straight bleach is to put some of it in a bucket, soak a mop in it and mop up the area repeatedly until all you can smell is the bleach. Once you have removed the odors, clean the floor with water so that the linoleum or the marble does not get damaged or discolored.
  1. Apple Cider Vinegar
Another excellent way to remove pet odors from the floors is to use apple cider vinegar. Apple cider vinegar is a natural bactericide. It can kill the odor-causing bacteria, allowing the floor to be clean and smelling natural. Apple cider vinegar can be used in concentrated form. However, it is best to use it mixed with water. You can mix together three parts of vinegar with one part of water and douse or mop the affected area of the floor with it. This can help remove the odor to quite an extent. Repeat the cleaning process until you can not smell the odor any more.
Last Word
Usually you can remove the odors with the help of these remedies. If the smell is especially strong, you may have to apply more than one of these cleaning agents to completely get rid of these odors.
 forum activity
