4 Best Uses for a Power Voltage Regulator
A power voltage regulator is a device that is designed to maintain the consistency of voltage output. Electronic devices in the home are specifically designed to accept only at a set maximum voltage. When the voltage suddenly increases, the unit can be heavily damaged. In some cases, the unit may receive very low voltages and thus fail to function. Therefore, the power voltage regulator has been created to ensure that none of these things happen. Here are some of its best uses.
1. Protect Home Electronic Devices from Damage
Electronic devices require electric power in order to work. However, there is only a set range of voltage that the unit can accept in order to function. Take for example a computer. When a computer is connected to a power source directly, it has the tendency to be damaged by fluctuating voltage, or short circuits. In order to protect the unit from potential damage, the user has to connect it first to a power voltage regulator. Other devices such as television sets, refrigerators, microwave ovens, and other electronic devices usually used at home are better used with regulators as well. Newer electronic devices already have built in voltage regulators, but older models have to have separate regulators for protection from high voltages.
2. Thermal Protection
High voltage running through circuits and into unprotected electronic devices can bring about expensive damage due to the high heat generated by such large amounts of power. Voltage regulators work by stopping the flow of large amounts of current into electronic devices and prevent from heat build-up. The regulator has the capacity to control and limit the amount of voltage entering a circuit, making it safe.
3. Surge Protection
Many voltage regulators also come with an added surge protection feature. Surge suppressors and voltage regulators are very similar devices because they both protect the electrical unit from damage caused by incorrect voltage, but they work using different concepts. It is best to use a voltage regulator with surge suppressor. This allows the connected unit to be protected in two ways – from fluctuating voltage and from abnormal power surges.
4. Ensures Consistent Flow of Voltage
The voltage power regulator does not only protect devices from high levels of voltage that will cause damage to the device. It also ensures that the device gets the correct amount of voltage at any time. As mentioned above, the voltage that passes through a unit can fluctuate. If the voltage is too high, it damages the device, but if the voltage is too low, the device will simply cease to function. In order to get the device functioning at all times when it is plugged, the voltage regulator taps into the source of electrical power and pulls out more voltage. This in turn results in a consistent voltage that allows the device function correctly at all times.
