Login Error
Close
4 Best Uses for Engineered Wood
by DoItYourself Staff
Engineered wood was invented in order to provide a more dimensionally stable form of wood. Engineered wood can be used in a variety of different applications and settings. Here are a few of the best uses for engineered wood.
1. Flooring
One of the most practical uses for engineered wood is in flooring. Engineered wood flooring has become extremely popular in the flooring market today. It has surpassed solid wood flooring as the most common type of hardwood floor. With engineered wood flooring, you are able to glue it down to a concrete subfloor, which is not possible in most cases with a solid wood. With this type of flooring, you are also going to not have to worry about the floor buckling as much. In most cases, engineered wood flooring is going to be less expensive than solid wood flooring because the manufacturer can get by with less waste. All of the tree is going to be used when making engineered wood flooring. When you try to make solid wood flooring, there are only so many pieces of wood that you can get out of a tree, and the rest is going to be wasted. The great thing about engineered wood flooring is that you cannot tell the difference between engineered and solid wood once it is installed. You can only see the top layer, which is exactly like a piece of solid wood floor.
2. Siding
Another popular use of engineered wood is for siding. Many companies are now starting to produce engineered wood siding instead of going with solid wood. With engineered wood, you are going to get a siding product that is much more durable and reliable. It is also going to be better with moisture and wear and tear. In most cases, it is also going to be less expensive than getting a solid piece of wood. Although these products had some problems in the early going, they are becoming a lot more reliable in today's market.
3. Ceiling
You can also install engineered wood on your ceiling. This provides you with a very rustic look and is very sought after in many areas. This is going to provide you with a very durable ceiling material that does not need to be replaced often. This is most likely going to be more expensive than some of the other ceiling options that you could choose, but nothing else is going to give you that look.
4. Subfloor
You can also use engineered wood as a subfloor. There are many types of plywood and engineered wood that makes a great subfloor for any type of flooring. You can nail it down to the floor joists, and it will be a very reliable and durable floor surface for you. At that point, you will be able to nail hardwood flooring down to the subfloor or install any other type of flooring that you can imagine.
 forum activity
