Login Error
Close
4 Best Uses for Epoxy Spray Paint
by DoItYourself Staff
Epoxy spray paint is a great product to use for a wide variety of projects. It comes in a variety of colors and is popular for its' adherence to a wide variety of materials as well as its waterproof properties. Epoxy paint can provide a long-lasting beautiful surface for years.
Appliances
Epoxy spray paint creates a long lasting, stain, scratch, and fade resistant surface. This makes it ideal for painting and updating appliances. It is also cleanable. You can use normal household cleaners on it. It resists stains, grease, and grim. Because of the variety of colors, matching the appliance you want to paint to other appliances in your home should be easy. Buy the colors that most closely your current appliance colors and test until you find the paint that matches. Or go crazy, and update all your appliances to a new color.
Waterproofing
Because of epoxy’s strong adhesive and water proof properties, it is perfect for painting boats, surf boards, and boogie boards. It sticks to a wide range of materials and creates a water proof surface when dry. As you are painting, it will also fill in and seal any cracks or chips in the surface of your project. Epoxy spray paint can also be used on furniture in sauna or pool rooms. The high moisture will not affect the furniture with the waterproof coating on it. Be careful. Epoxy paint will yellow and fade quickly when exposed to direct sunlight. It will also become brittle and flake off. If you have furniture you need to paint that is around an outside pool, you might want to consider using a different type of paint.
Indoor Projects
Decorating your home with epoxy spray paint has a number of advantages. Epoxy can be applied to concrete, wood, and metal. This makes the paint suitable for a variety of purposes. It can be used for cabinets, bar tops, and counter top. It is also good for closet doors and crown molding. Epoxy spray paint has very little odor, making it ideal to use in your home. The dried surface is hard and durable, and will stand up to the normal wear and tear of daily life.
Bathrooms
It can also be used in applications where other paints would not be suitable. Bathroom surfaces deal with a large amount of moisture from showers and baths. The steam causes humidity. Epoxy spray paint can be used to paint tile, sinks, and bath tubs. Again, epoxy paint will resist the moisture and create a long lasting surface. It easily can be used to update the look of your bathroom.
These are only a few of the uses for epoxy spray paint. Just about anything that can be changed with paint, can be changed using epoxy paint. Your imagination is the limit. Plan your project and go to the local hardwood store for your epoxy spray paint today!
 forum activity
