Login Error
Close
4 Brick Mortar Cleaning Tips
by DoItYourself Staff
By undertaking the process of cleaning brick mortar and knowing how to do it properly, you can be assured that your home will always look its best. By considering the process necessary and implementing some tips, you will ensure that the cleaning process is completed properly and without causing any damage.
Step 1 – Inspect
Don’t assume that the brick mortar requires a specific type of cleaning treatment without examining it first. Where the debris is extensive or stubborn, a suitably extensive method must be used to clean it. This will not be necessary where there is only a light amount of dirt. Be aware that cleaning can be required as a result of airborne pollutants as well as normal weathering. This step will also give you the opportunity to determine the extent of the mortar that requires cleaning.
Step 2 – Chemicals
There is a wide range of chemical cleaners on the market that can be used to clean brick mortar. However, this does not mean that it is safe to use any of them. In addition to containing toxic substances that can harm the environment, there are some that make use of acids to put the cleaning process into effect. Many of these acids will erode the bricks and mortar if left in place for too long and not used per the instructions. Other cleaners may cause damage to trim or surrounding areas. Make sure that you read the instructions carefully and use a cleaner suitable for the level of dirt affecting the wall. You must also ensure that you obtain a quantity that is sufficient for the entire wall. When using chemicals, make sure that you wear the correct safety gear to protect yourself from harm.
Step 3 – Tools
Obtain all the tools that you will need for the brick mortar cleaning process prior to starting. In some cases, a pressure washer will make the task easier, and these can be hired from an equipment rental company. Get advice on the right type of pressure washer for the job. This tool should be tested on an inconspicuous section of the wall initially as the mortar can be forced loose if the strength of the spray is too heavy. Alternatively, the task may be able to be completed with the help of a wire brush before being rinsed manually. You will also find it necessary to have an A-frame ladder, bucket, hose and a plentiful supply of water.
Step 4 – Repair
In the event that any section of the brick mortar requires repair, it is best to complete this prior to undertaking any cleaning. In some cases, cleaning defective sections of the mortar can cause further damage. Refill any sections of the wall where the mortar has come loose and leave it to set completely before proceeding. Pay particular attention to any missing bricks or cracks in the mortar, which may be a sign of a more serious problem, such as ground heave or subsidence. When this is the case, engage a professional to undertake any rectification work necessary.
 forum activity
