Login Error
Close
4 Carpet Laying Tips
by DoItYourself Staff
The process of carpet laying is not particularly complicated, but it does involve some hard work. Many people opt for professional installation. However, you can do it yourself if you have the right information and a willingness to work. Here are a few carpet laying tips that may help if you opt for self-installation.
Allow Extra
When installing new carpet, many people want to purchase the least amount of material they can. However, you should not try to cut corners when buying carpet. Carpet comes in rolls, and you need to make sure that you get a piece big enough to cover your room. You will also need extra carpet for seams in larger rooms.
If you have trouble with calculations, you can ask a professional to measure the area for you and let you know how much carpet you need for the job. Allow a little extra, especially for carpet laying in those larger rooms.
Plan for Seam Placement
Before you begin installation, you will want to come up with a plan for where the seams will go. Keep in mind that you have to run the carpet the same direction in every room that is attached. Therefore, you cannot turn the carpet in another direction in the hallway or bedrooms.
As a general rule, you will want to run the seams with the direction of the light. If light is going with the seam, you will not be able to see it as easily. However, if light goes across the seam, it will cast a small shadow, and you will be able to see it more easily. In addition to light considerations, you will also want to consider where your furniture will sit and where the main traffic areas will be. If you can put a seam underneath a couch, no one will be walking on it and no one will see it.
Use a Power Stretcher
While you will need to use a knee kicker around the edges of a room, you should also use a power stretcher in most rooms. A power stretcher will allow you to get a good stretch on the carpet and will prevent it from needing to be stretched in the future.
Take Your Time on Seams
When putting together a seam in your carpet laying, you will want to make sure that you take your time and do it correctly. You should put the seam together correctly in order to make sure that the carpet stays together and looks good. Many people get in a hurry and will overlap their seams or leave a gap.
 forum activity
