4 Common Dual Hose Portable Air Conditioner Problems
When it gets hot, a portable air conditioner can be a great benefit for cooling your home or room, and a dual hose portable air conditioner is a great step up from the single hose model. Despite its benefits, there are some problems associated with this type of air conditioner. Read on to learn more about these problems and how you can fix them.
1 - What Goes in Must Come Out
A dual hose air conditioner pulls air in to cool through one hose and exhausts warm air through another. This is fantastic if you have an open window to put the hoses through. However, one of the main reasons people get standing portable air conditioners is because they do not have access to an opening window in the room they’d like to cool. Otherwise, they might get a window unit. This leaves you with the problem of having all the hot air pumped back into the room you are trying to cool. Usually, this air is so warm it actually ends up heating the room.
2 – Not Easily Portable
A dual hose air conditioner is supposed to be portable from space to space, depending on which area you want to cool. While these units are designed to be portable, they are still not very lightweight, and the more power they pack for cooling, the larger the model gets. Most of them do have wheels, which makes it easy enough to move it from room to room on the same floor, but if you want to get it up stairs, you could be left wondering just how portable it really is.
3 – Cooling Methods
Unlike a window unit, a portable air conditioner cools an average space of about 150 square feet. This is great for a bed room, but not so good at cooling rooms like the living room or the family room. If you do manage to get it up the stairs and get the tubes out of an open window you still may find that it does little good at cooling you down while you watch TV with your family.
4 – The Noise Factor
All air conditioners are a bit noisy, but dual hose portable air conditioners can seem like they’re competing for the prize. Because the whole unit is inside the room, as opposed to a wall unit that rests partially in and partially out, you get all the noise of the machine in there with you. While some people can easily tune this sound out, others may find it difficult to sleep, hold a discussion or watch TV with their air conditioner roaring in their ears.
There are a lot of things to consider before you decide on a dual hose portable air conditioner. While it can be a great way to cool you house with only one unit, there are some draw backs. Consider if the rooms you will be using it in have windows to vent it through. Consider how much you plan to move it and how big of a space you want it to cool. Make sure you know what you are getting, rather than being disappointed with your purchase.
