4 Common Truck Brake Repairs
You can fix a number of common brake problems with some simple truck brake repairs. Repairing the brakes when they only show mild problems can help to prevent serious accidents or at least inconvenience. Performing simple truck brake repairs can also prolonging the life of your vehicle. But if you encounter a serious problem during your repairs, call in an experienced mechanic before you drive the truck again.
Sticking Brakes
Sticking brakes are common in any kind of vehicle. Brakes start sticking due to a buildup of grease or brake fluid. Check for this buildup every time you maintain your vehicle. Remove any buildup you find with a degreaser and replace any parts, including the brake linings, that have been overwhelmed by fluid.
If you continue to experience problems after you cleaned away the grease, you may have a problem in your rotors or drums. If so, you will have to resurface these in order to avoid sticking brakes.
Squealing Brakes
The squealing sound is caused by vibrating of the brake pads against the caliper. You can use the following truck brake repair to address squealing breaks.
Take off your old brake pads and replace them with new ones. Apply a dab of grease to the new pads to minimize noise in the future. Complete this truck brake repair soon after the squeaking begins; neglecting the repair can damage the brakes and cause expensive repairs.
Brakes Dragging to the Side
Brakes may drag to the side. Although barely perceptible at first, they will eventually pull the car slightly to the left or right every time you brake. This condition may not always reflect a problem with the brakes. (It can be a problem with the axle, the steering wheel, or the wheel bearings.) However, you can try fixing it by making sure the brake adjustments are equal on both sides. A stronger adjustment on one side will cause the car to turn.
Sunken Brake Pedal
In older vehicles, you might see the brake pedal sinking toward the floor. In some cases, you may have to grind the pedal into the floor of the vehicle before you come to a stop.
You might address this problem by changing the master cylinder in the truck. But even after changing the master cylinder, you may find the brake pedal remains sunk into the floor. In this case, do not attempt to drive the vehicle before it receives more extensive truck brake repair. The sunken brake pedal presents a dangerous situation, as it can arise from a leak in the brake hydraulics. A leak may stop the brakes from exerting pressure and therefore cause your brakes to fail.
