4 Copper Kitchen Sink Cleaning Tips
Having a copper kitchen sink can give your cooking area a more classic look, but unlike ordinary kitchen fixtures, copper sinks require special care if they are to be used for many years. For proper maintenance of this type of sink, here are some important cleaning tips to keep in mind.
1. Wipe Sink after Every Use
Unlike other materials used to make kitchen fixtures, copper is said to have antibacterial properties. This means that simply wiping the copper sink with a piece of cloth is good enough to ensure that it is clean. Wiping the sink after each use will also help in preventing the discoloration of the sink surface.
Avoid using chemical-based cleaning solutions, particularly acid cleansers. The protective coating used in copper sinks can be easily damaged by substances with very high levels of acidity. Even vinegar and citrus fruits or juices can ruin copper surfaces. Once the protective layers are worn out, your entire sink could easily become corroded. If you want to polish your copper kitchen sink and you really must use cleaning agents, make sure to have solutions that are specially made for copper surfaces.
2. Do Not Allow Water in the Sink to Dry Out
Apart from the fact that you need to wipe your copper sink after every use, you also must not let water in the sink dry out on its own or at room temperature. Any water buildup in the sink that has been allowed to dry out will cause discoloration on the copper surface. This effect is basically due to the mineral deposits found in water. Therefore, even if you have not used your copper sink, you need to wipe it dry whenever you see water on the surface.
If your sink is clogged, be sure to have it fixed immediately. While waiting for the drainage to be put back in working order, it would be a good idea to scoop out still water and wipe the copper surface dry.
3. Never Use Abrasives on a Copper Kitchen Sink
On top of acids and other chemical-based cleansers, you should also stay away from abrasive materials when cleaning your copper sink. Using abrasives can speed up the deterioration of copper surfaces. When that happens, you will see unwanted spots on your sink. These discolorations are not only ugly to look at, but they can also cause a rusty stench in your kitchen’s wash area. A damaged copper sink will require resurfacing or total replacement done by a professional.
4. Apply Polishing Wax Occasionally
To best preserve the immaculate appearance of your copper kitchen sink, make sure to apply special wax designed for polishing copper surfaces. This type of application can take away water stains and other unwanted spots that may be developing in your sink surface. Waxing can be done once every month. However, if you have been consistent in applying the special cleaning tips for copper sinks, then you can opt to apply the polishing wax once every two months. Just be sure to deal with discolorations as soon as they appear.
