Login Error
Close
4 Copper Wiring Devices
by DoItYourself Staff
Copper wiring is a traditional fitting for electrical wiring. Copper wiring devices have been used since the beginning of electricity, and they are still in popular demand. There is increasing competition from aluminum wiring, but the latter is often considered to be a more unstable, hazardous electrical connector. Due to the popularity of copper—which is cheap and has a stronger resistance than any metal other than silver—there are still a large number of devices that use copper wiring as part of the system.
Gas Fireplace
You may be surprised to hear that a gas fireplace often has copper tubing and wiring as part of its operating systems. Gas fires use copper as it is considered to be flexible, reliable, and less flammable than other wires. It's cheap availability also helps to keep down the price of gas fires for the general public. Copper wire is also better for a home with gas fires, as the heat will not affect copper conductor wiring. The bigger problem is heat around the wire melting the plastic outside. Modern wiring in new build houses is made to withstand a higher heat than old-fashioned homes.
Telephones and TVs
Your telephone will also be part of the many devices which use copper wiring in the home. The TV and DVD systems will also be connected to copper wires, as they can efficiently distribute video, audio and internet services. Multiple cable systems are also typically attached to copper wires. Fiber optics are also made out of copper wires connected in twisted strands. Copper connections are considered to be more reliable and better for the digital age than the fashionable but risky aluminum wire. In fact, it would not be a good idea to use a number of telecommunications modules inside one home if you are dependant upon aluminum wire.
Computers
Most modern computers use copper wiring in their internal systems, networks and internet relay devices are usually connected via copper wires to electrical systems. Copper wire can carry and distribute digital images to computers better than aluminum and other metal relay systems. The wiring most often used with copper wiring devices is the Category 5e, which is then installed in a star shape, from which separate lines run off into individual rooms. Most modern devices, such as the Wii and the Nintendo DS, have copper wiring components in the machines, and electrical designers include a range of copper wiring systems within new models of their products.
Energy Efficiency
Given copper wiring's capacity to carry high levels of current, it is no surprise that copper wires are used for their energy efficiency. From greater car efficiency to energy efficient refrigerators, copper wiring is considered to be a more suitable use of metal in wiring that aluminum. Replacing your aluminum fixtures in the car with copper wires can help to improve the ability of your car to use fuel and energy. Refrigerators also have copper wiring in them, which helps them to carry more energy to its intended spot, and thereby helps to save electricity.
 forum activity
