Login Error
Close
4 Different Types of Outdoor Lanterns Explained
by DoItYourself Staff
Strategically-placed outdoor lanterns and lights can add ambiance and style to your deck, patio or garden. There are dozens of styles to choose from, so here are a few design ideas to get you started.
Wall Lanterns
These are great options if you want some light by your front door. You could go for a sleek, modern design that makes it look as if the light were floating along the wall, or you could choose a more traditional lantern with a pointed iron top and glass sides. To make the look symmetrical, plan for a wall lantern on each side of the door. If you have the space and an overhang, you could place a larger hanging fixture from the same family above the doorway to give your home a cohesive style from the outside in.
Post Lanterns
Post lanterns are great outdoor lanterns that can illuminate walkways or stand on either side of doors. A single one can accompany a mailbox on the front of a property. Again, you can find a post lantern that fits your favorite style from pagoda designs with pointed tops and sloping sides to fixtures made of black iron, antique brass or even ones with intricate patterns that make the lantern look like a miniature gazebo.
Pathway Lighting
If you have paths on your property, consider pathway lighting for safety and security. Pathway lighting can take on many forms, from post lanterns to smaller outdoor lanterns that sit close to the ground. You could also opt for outdoor flood or spotlights that would give you bright bursts of light with minimal fixtures if you just want something simple. Alternatively, you could go for more ornate styles; small pagoda lights in your garden have a Far Eastern feel. You could also choose traditional housing for your outdoor lights.
Pier Mounts
This kind of outdoor lantern is usually overlooked but can be a great option if your property is lined with a fence. Pier mounts work with post lanterns, but the mounts fit on the side of your fence so you can illuminate right around your property. There are so many materials to choose from--frosted glass, slate or wrought iron to name just a few. The great thing about pier mounts is that you can have these outdoor lanterns installed while your new deck or fence is being constructed so you don't have to wait until additions are installed.
Electricity
One thing to keep in mind with outdoor lanterns is that you will need to buy light bulbs and ensure that you keep up with changing them when needed. Wall lanterns will be connected to a junction box, which is usually located outside. Your electrician may need to run wires through your walls to connect them into the main electrical network. Pier mounts or post lanterns are wired through the ground. Make sure your electrician fits the wires inside PVC tubing before connecting them to an outdoor junction box.
Choose low voltage lines for home use. Twelve volts is ideal.
 forum activity
