cancel
Job type :
Zip Code :
community forums
comments
4 Entry Door Styling Tips
Doing home remodeling can sometimes include changing the entry door and there are several things to consider if this is the case in your home.  You might have thought before that a door is a door is a door; however, there is much to consider in this investment.
The Benefits of a Big Entry Door
Standard entryway doors are anywhere from six foot six inches tall to six foot eight inches tall. If you have tall ceilings inside, you may want to increase the height of your entryway door.
You also may want to add-on length wise to include architectural glasswork or windows.
You might even consider going with the double door or French door opening. This can certainly open the space and bring in some natural light.  Plus, another benefit to double doors is that it becomes easier to move big things in and out of your home.
Materials for Classic of Contemporary Style
First there is the standard solid wood door with the option of different types of wood, such as oak, maple, cherry wood, teak and mahogany. This is a good option for older homes and classic looks. Make sure the door is pretreated and durable if this is your choice. Also, make sure it flows together with the rest of the house; think resell value.
There are contemporary steel doors, which are a good option if you are looking for sleek and strength.
An economical solution is medium density fiberboard (MDF).
Choosing a Unique Shape and Style
There is rarely a door any more that is just plain old rectangular board. There are thousands of styles and shapes to choose from. Make sure the style you choose is uniform with the type of home it is; again, resale value counts.
Hardware Provides Finishing Touches to Door Style
You might not even think of this as a styling option, but it is. You can decide for yourself what style to ‘decorate’ your entryway door in and there are plenty of options so take your time.
First there are the knobs and locks; do you want old-fashioned looks or simple lines? Consider the metal used and how this will match the type of door you chose.
You can add a kick plate and it can be any size or color you want. Even the panels of the entry door can be unique to you and your home. You can add windows, stripping and jams.
The main thing is to find something that fits your home well and is affordable to your budget. You can make small changes that cost only a few dollars or the change could set you back over a thousand dollars, it’s up to you.
member comments
Did-it-myself Projects
updated by FelipeBR
did this on 9/22/2009
Iphone Bus Holder
updated by SolarPanel
did this on 8/29/2009
Home Build Solar System
updated by dorfin
did this on 3/30/2009
Recoil Starter Repair
Painting Stylish Wall Borders
sponsored articles of the day
