Login Error
Close
4 Greenhouse Insulation Options
by DoItYourself Staff
Installing greenhouse insulation is very important in reducing heating costs and increasing efficiency. If you live in a cold region and have to maintain a high temperature in your greenhouse, insulation can save you a lot of money.
Before installing insulation in your greenhouse, it's important to understand the different insulating materials available on the market. Some of them reduce the amount of light that reaches the plants, so make sure you choose something that won't damage or kill the plants in the greenhouse.
Double Glazing
This is the most efficient way to insulate an entire greenhouse. If you plan to use this type of insulation, make sure it's added to the greenhouse as it is being built. This is an expensive type of insulation, but it provides a lot of benefits.
Bubble Plastic
This is another type of greenhouse insulation that is very efficient. Bubble plastic is made up of double or triple skins of transparent plastic that contain air cells in between. This type of insulation lasts for three or four seasons before it needs to be replaced. It is a cost effective way to insulate a greenhouse.
In comparison, one layer of plastic sheeting is much less efficient than bubble plastic at preventing heat loss. However, plastic sheeting is less expensive up front and won't cut out as much light. You can use plastic sheets in the winter to create a double glazing affect in the greenhouse. Just attach some to the structure with clips that fit into the frame.
Thermal Screens
This type of greenhouse insulation consists of clear plastic or translucent material, such as cross laminated fabric. The material is attached to wires between the eaves. You pull the screens horizontally across the width of the greenhouse at night. These screens are perfect for conserving heat during the night. They work by restricting the amount of heat that can rise above the eaves and trapping the warm air lower down in the greenhouse, around the plants. These screens are also handy for sectioning off a heated area on one end of the greenhouse, if you want to leave the rest of the greenhouse unheated.
Base Cladding
This is another option that is installed on the floor of glass greenhouses. This type of insulation reduces heat loss by a significant amount. You can also place polystyrene panels on the foot of the glass panes for added insulation. Just make sure that you remove them before the summer arrives.
As you can see, there are many different options when it comes to greenhouse insulation. The type of insulation you choose will depend on the plants you want to grow in the greenhouse, as well as the size of your greenhouse.
Larger greenhouses may require a certain type of insulation to effectively trap heat in the structure. The type of insulation you choose also depends on your budget and the environment you are trying to create within the greenhouse.
 forum activity
