Login Error
Close
4 Halogen Lamp Safety Tips
by DoItYourself Staff
Also known as quartz iodine lamps or tungsten halogen lamps, a halogen lamp is an indoor light fixture that has a tungsten filament securely encased within an envelope. This envelope is small, transparent and filled with halogen gas, hence the name. Affordable and attractive, halogen lamp bulbs are long-lasting and emit a bright, cool and white light that makes them popular with many. However, it is important to follow a few safety tips, since these lighting fixtures operate at a much higher temperature compared to other lamps.
Here are 4 halogen lamp safety tips that you must keep in mind while using one at home.
1. Certified and Tested Lamps
Always buy a lamp that has been certified or evaluated by an established testing body, such as the Underwriters Laboratories or CSA International. The CSA International and Underwriters Laboratories provide standards to ensure and increase the safety of these lighting fixtures.
2. The Right Light Bulb
Before using the light, always read the instructions to identify the type of recommended bulb. The wrong bulb can cause the lamp to shatter. Also, never touch a halogen light bulb with bare hands and be sure that the lamp is unplugged and cool to the touch before beginning to change a bulb. Bare hands can leave an oil residue on the bulb, which can increase the risk of fire. Always wear gloves when touching a cool halogen bulb.
3. A Safe Environment
These indoor light fixtures should not be used in homes with kids and pets, since children and pets may attempt to play with them or cause these lamps to tip over. Never place lamps near windows, beds or any other area where fabric may hang near the top of the lamp. Do not drape any type of fabric over the lamp. Also, never place the lamp near any area where the lamp, bulb or its protective covering may come in contact with any kind of combustible material. When placing them near the wall or a bookcase, ensure that there is a distance of at least 20 inches between the lamp and the wall.
4. Safe Operation
Always read the instructions and warnings before beginning to use a halogen lamp at home. Do not operate a halogen light if there are missing or damaged parts. Avoid leaving lamps with a wattage of 100 or more on in an empty home. Also, turn the lamp off when not needed or when you leave the room. Use a dimmer switch, if available, at the lowest setting when possible. This helps reduce overheating and extends the life of the bulb. Never operate the lamp over and above the rated voltage.
Halogen lamps can provide bright, lasting light and can create a dramatic décor statement in a room. Still, it is important that safety be of utmost regard. Following instructions, keeping lamps away from combustible materials and not using them in areas where they might be tipped are some of the considerations that you must keep in mind before beginning to use them at home.
 forum activity
