4 Helpful Basement Waterproofing Products
Basement waterproofing is crucial for preventing mold, mildew and water damage. With a waterproofed basement you can utilize the space for storage or finish it and add another living room or den to your home. There are many products which can help you to waterproof your basement. Being knowledgeable about all of them will help you to make an informed decision about which one is right for your home.
Sump Pumps
A sump pump is most useful in homes where the water table is above the foundation of the home. This causes regular basement flooding. To stop this from happening and to remove dampness, a sump pump is installed.
There are two types of sump pumps: pedastal and submersible. A pedastal is mounted above ground and may be more easily reached, though unsightly. A submersible is located below ground and is sealed off.
Sump pumps sometimes are powered by the pressurized water in the home. If not the pump will be connected to the home's electrical supply, but it's important to have a battery powered back-up in case of a power outtage.
Drain Tile Systems
Traditional drain tile systems (or French drains) use regular PVC pipe to channel out water and are notorious for failing and giving homeowners the headache of a flooded basement. If this is the system in your home, you might want to upgrade it. There are several new piping systems that can be installed in both internal and external drain tile systems to give you greater piece of mind
Baseboard Systems
Baseboard systems originated in the midwest in the early 1960's. The design is simple and very effective. Hollow baseboards collect water from weep holes tapped in the bottom row of blocks and channel the water to a sump pump or floor drain. This approach to waterproofing your basement can save hundreds of dollars over sub-floor systems.
Cavity Drain Systems
In a cavity drain system a pre-formed cavity within your basement intercepts incoming water and drains it away. The cavity collects groundwater within your structure and then drains it away. This system is located entirely under ground. When utilizing this system, you must select a suitable cavity to work with your structure, so that it provides the proper amount of pressure to control the amount of water. Additionally, you should also consider the external drainage, the amount of groundwater, soil type and ground contamination.
Other Waterproofing Ideas
To prevent leaking and flooding in your basement it is important to first fix, fill and repair all cracks and holes. Survey your basement and carefully check the walls and ceiling for any potential gaffs. By fixing these you will prevent excessive water from seeping into your home and causing damage.
