4 Home Remedies for Mildew Odor Removal
There are different mildew odor removal procedures that you can do using common household items. With these simple home remedies, there is no longer any need to get strong chemical solutions that may have harmful effects to your health.
1. White Vinegar
Clothes stuck for a long time in cabinets can have mildew odor but there is a simple way to remove the smell from these clothes without using chemical solutions. White vinegar is a natural product that you can use to remove mildew odor. The acidity in the vinegar is a great deodorizing ingredient since it attacks the molecules that create this odor.
To remove the mildew odor using white vinegar, add 1 cup of white vinegar during the cold water rinse but do not use any detergent powder. When completed, wash the clothes using the normal process.
2. Baking Soda
Just like white vinegar, baking soda is a great natural product to remove any smells due to mildew. It also has deodorizing components that attacks and neutralizes acidic molecules. There are several ways you can use baking soda as a deodorizer.
You can use baking soda as a natural air freshener in places where the odor of mildew is apparent. These include basements, attics, closets, cabinets, or any damp and enclosed areas. All you need to do is open a box of baking soda and place it in these locations or you can put an adequate amount in a container making sure that it is open to allow air to circulate in the container.
You can also use baking soda to remove any mildew odor in your clothes or towels. To do this, just add a few spoonfuls of the baking soda to each laundry load. It will easily remove the smell.
3. Cat Litter
Another uncommon, yet effective, home remedy that you can use to remove the smell of mildew is to use cat litter. Cat litter has deodorizing ingredients that make it an effective deodorizer for cat litter. Using cat litter to remove mildew odor is suitable for rooms or spaces where the smell is apparent. Place a box of cat litter in these areas making sure that the box is open. In effect, the cat litter will act as a natural air freshener.
4. Hydrogen Peroxide
Hydrogen peroxide is another solution that you can use to remove mildew odor or musky smell in your home. It is advisable though that you should not use this strong chemical solution as a deodorizer for clothes or any soft material or surfaces. This may ruin the clothing or cause stains. Hydrogen peroxide has very strong oxidizing properties making it a good bleaching product so extra precaution is needed when using this solution.
However, you can create your own deodorizer using hydrogen peroxide. In a sprayer, mix 1 part of the hydrogen peroxide and 2 parts of water. Make sure that you use a 3% hydrogen peroxide solution. Spray this solution in areas where the mildew or musty odor is present. Be sure to spray away from any surfaces that will react with the solution. Allow the solution to work for a few hours. You can also use this solution to remove the mildew smell from drawers, sofas, or any heavy-duty items. Let it sit for a few hours and rinse the material.
