Login Error
Close
4 Methods of Tile Grout Removal
by DoItYourself Staff
Each method for tile grout removal is different, they all work very well. At the end of the task you are going to have to clean it out the same way for each, but getting there can be accomplished with several different techniques. Here is a little more information to help you decide which method is best for you.
Grout Saw
Make sure that when you are using the grout saw you are protecting not only your eyes and hands but also the furniture or any other fixtures in the room while you work. You can do this using plastic sheets hung or taped. When you start sawing you are going to want to begin by cutting a groove. Typically the grout will be porous and you will only have to do it for a few seconds until it becomes loose enough to get out. Once you have gotten the bigger pieces of grout out you may want to use a scraper or chisel to get the smaller pieces.
Grout Scraper
This tool looks a lot like a screwdriver but with a triangle on the end of it. You can find it pretty inexpensively and it is amazing at getting the grout off. You can use the scraper to really get into the grooves and pry the grout out. A hammer and chisel may be able to help you if you get stuck with pieces that won't move.
Rotary Tool
Any rotary tool will work, especially those that are a lot like the grout saw. You can find them for cheaper and you will use them just like the saw is used. Again, like the saw you will just have to loosen and cut into it for a few seconds to get it out. Then you may want to use a smaller tool like the chisel to get the tiny pieces that won't budge out.
Hammer and Chisel
A hammer and chisel can work a lot like a grout scraper but sometimes they an even be better. this is because you can really get in there with the chisel and then use the hammer to pry out any of the grout that refuses to be removed. Basically all you will have to do is stick the chisel in there and begin to hammer away.
Each one of these methods will work. Depending on the amount of time that you have on your hands as well as the toughness of the grout and your experience with saws, you will have to decide which method is best for you. Then you can use a vacuum to get the tiny pieces as well as the debris out. Once you have gotten the grout out though no matter which method you decide on, you will have to make sure that you clean out the lines and cracks where the grout was so that you can fill it in later and the new grout will stick. Good luck!
 forum activity
