Login Error
Close
4 Methods to Clearing a Clogged Sink
by DoItYourself Staff
If you're frequently faced with a clogged sink, you should know the most effective way to clear stubborn sink clogs. It may interest you to learn that there are several easy, highly effective methods of unclogging your sink. Try a few of the methods below.
1. Using a Sink Plunger
A sink plunger can often prove to be an invaluable tool in clearing clogged sinks. This helpful tool works in much the same fashion as a traditional plunger and is very easy to use. To use sink plunger for unclogging purposes, simply fill the clogged sink with a small amount of warm water, and firmly position the sink plunger over the base of the drain. Proceed to give the drain a thorough plunging using powerful down-and-up motions. Continue in this fashion until the sink once again drains normally.
As plunging certain clogs can be a physically taxing procedure, it is important to take periodic breaks when dealing with clogs that require an extensive amount of plunging.
2. Running Hot Water
Hot water is a fantastic tool for clearing up lighter clogs. To expel a clog with hot water, remove any drain guards or drain traps, and proceed to run a steady supply of very hot water into your drain. If this method fails to produce results after 10 minutes, you are most likely dealing with a heavy duty clog.
Additionally, as a preventative measure, it is recommended that you allow very hot water to flow into your drain for several consecutive minutes every week. This will help clear up assorted grime, grease and hair before these substances are able to form a clog.
3. Using a Drain Snake
A drain snake is a very useful tool for unclogging sink and bathtub drains. To use this tool, carefully insert the hooked end into your clogged drain and slowly move it downward until the hook has latched onto the source of the clog. Next, gently shake the clog loose and slowly retract the drain snake with the clog's source in tow.
4. Using an Unclogging Solution
If all else fails, you may want to try using a commercial unclogging solution, such as Drano or Liquid Plumber, to clear up your clogged sink. When pouring these products down your drain, make a point of only using a little bit at a time, as they contain potent chemicals that can eat away at your pipes if administered in large amounts. Once your unclogging solution has been applied, allow it to sit for 15 to 30 minutes so it has plenty of time to dissolve the source of the clog.
After your clog has been successfully cleared, it is recommended that you give the sink a thorough cleaning to remove any lingering traces of the product. Also, it is very important that you never mix 2 kinds of unclogging solutions, as certain chemicals found in these products can produce hazardous fumes and chemical reactions when combined.
 forum activity
