Login Error
Close
4 Mistakes to Avoid when Installing a Door Jamb
by DoItYourself Staff
If you want to install a door jamb in your home, then you should be aware that there are a number of mistakes which you can make that should be avoided if you don't want to have to redo the jamb. Fitting a door jamb is not a very difficult task, but if you don't do it carefully, you will find that you end up in an awful mess, and this could leave you without a door which closes effectively, making you vulnerable to intruders. Getting the door jamb to fit correctly, and then to secure the door, is the ideal outcome from this installation, and if you avoid making silly mistakes, then that is that you should achieve. Watching out for basic mistakes is a good idea no matter what kind of home improvement you are doing.
Avoid Measurement Mistakes
You can never be too careful when you are taking measurements. Sometimes measuring twice is not enough to rule out silly mistakes. Write out all of the measurements that you need to take in a notebook, and then use this to keep a record of the results. You should then repeat the measurements, making a note of these. If there is any discrepancy, you should remeasure until you have a consistent result. This is the only way to ensure that you get the perfect fit for your door jamb.
Avoid Cutting Mistakes
If you measure correctly, then you are half the way to getting your cut correctly. You need to mark the cuts out clearly with a piece of chalk, and check the measurement is correct before you begin cutting. Work slowly towards the cutting, and compare the length of the wood being cut to the door to make sure that you are not cutting off too much. You need to cut the wood on a machine, so make sure that it goes in level, and is not damaged when you take it out.
Avoid Nailing Mistakes
It is a silly mistake to begin your nailing when the jamb is being fitted above your head. Begin by making pilot holes on the floor or cutting table, and place nails through each of the holes, tacking it into place with your hammer. You can then use your level to measure the fitting as you proceed. Tap the nails into position, and then use a shim to level up the door jamb before the final nail. You may need to leave a little room between the wall and the door jamb, but this can be filled with caulk later.
Avoid Installation Mistakes
Make sure as you fit the door jamb into the hole that you are fitting it the correct way around. There is nothing more annoying than placing the door jamb perfectly, only to discover that it was the wrong way around all along. Avoiding silly mistakes like this is part of the skills of a home improvement expert.
 forum activity
