4 Money Saving Kitchen Renovation Ideas
If you're looking to make some kitchen renovations in your home, there are a multitude of different ways for you to tackle your project. While many people assume that making a renovation or update to your kitchen requires that you make major changes and spend a lot of money, there are also many smaller things that you can do that can provide a fresh look and aesthetic for your kitchen space. Consider the following money saving renovation tips you can use when remodeling your kitchen.
1. Paint or Finish the Cabinets
The cabinets in many kitchens serve as a primary focal point. If the cabinets in your kitchen protrude from the walls, and especially if they are situated approximately at eye level, it is easy for them to quickly grasp your gaze when you look around the room. Thus, making changes to the cabinets in particular can give the space an entirely new feel.
Consider how your kitchen cabinets are currently set up. If they have a wood finish on them, you can strip off the finish and change it to a lighter or darker hue to significantly affect the feel of the space. If, on the other hand, they are painted, consider painting the outer portions of the cabinets in a new color for the same affect.
2. Paint the Walls
Because paint is a relatively inexpensive component of a remodeling project, and because it can dramatically affect the look and feel of a space, it's oftentimes a good idea to consider how painting your kitchen walls might improve the appearance of the area. If you have wallpaper in your kitchen, consider removing it and cover the wall up with paint instead. You can change from a lighter color to a darker one, from a darker to a lighter, or you can set up a patterned or textured paint design to provide even more of a unique appearance to change your kitchen space.
3. Replace the Countertops
Countertops in a kitchen are another area of focus. Because you'll be spending a lot of time in your kitchen working with items on the countertops, you can become used to their appearance. Consider replacing the countertops in order to improve the aesthetic of the room. There are many different types of countertops to choose from, and many of them are quite affordable. Look for plastic compounds and inexpensive stone options for the countertops in your new kitchen.
4. Change the Knobs and Handles
Other small items in your kitchen that can have a major impact on the way that you see and perceive the space are the handles and knobs on the various drawers and cabinets. Consider installing new knobs and handles for a low cost method of improving and changing the appearance of your kitchen.
These and other items that are necessary for different types of low cost renovations are available at most hardware stores.
