Login Error
Close
4 Most Popular Styles of Wood Home Theater Cabinets
by DoItYourself Staff
Home theater cabinets come in a range of different materials and styles, so finding the right one for you can be a real problem if you don't do your research. The type of cabinet you require would depend very much upon your personality, and what you enjoy in life. Some people, for example, might want a metal cabinet, which is basic and utilitarian, while others might want one made from metal piping and leather, which is more decorative. Perhaps the most common choice of home theater cabinet, however, is one which is made of wood. Installing a wooden cabinet into your home theater can make it blend in better with other furniture, add a touch of class to the room, or even provide a theme on which the rest of the entertainments room is based. Choosing between the styles of wood home theater cabinets can be difficult, but by knowing what you want, you should get a better idea of the right cabinet for you.
1. Crafted Wood
Perhaps the most expensive types of wood home theater cabinets are those which reflect historical periods. For example, a baroque cabinet would have exquisite carving and decorated panels, and may even feature materials on these panels. The cabinet would be designed to look antique, and the wood is often given a veneer in order to enhance it even more. This type of home theater cabinet would be very costly, and probably only suitable for those who have the money to maintain it, and a large enough theater for these to fit into.
2. Flat Wood
Medium range cabinets would be those which, while not elaborately decorated and carved, will probably also have veneers and colored woods, sometimes in three or four different colors. These types of cabinets are custom or specialist shop designs, rather than the sort you might find in a furniture warehouse. If you are looking for these kinds of cabinets, then you may be able to order from the world wide web, or you might find that local stores and carpenters can supply cabinets which fit into this range. These types of cabinets will be less expensive than your baroque carved home theater surrounds, but they will also not be the cheapest available. When looking at these cabinets, pick a color which suits your home, rather than one which is more exotic but would stand out from your home too much.
3. Store Cabinets
Stores often sell cabinets which are not quite medium range, but not yet the sort of Do-it-yourself cabinet packs. These types of furniture are usually sold as a single piece, ready made, but much more cheaply than you might be able to find on the high street. The range is not great, and you may end up with a very boxy-looking cabinet, which is nevertheless more hard wearing than the cheaper version.
4. Assemble at Home
The cheapest sorts of wooden home theater cabinets are those which are sold in furniture warehouses. These will often come as flat-packs, and have to be built into a cabinet by the purchaser. These types of cabinets often look very boring, and will mainly serve to keep your videos behind a door rather than adding to the appearance of your room.
 forum activity
