Login Error
Close
4 Must-Have Humidity Control Products for Your Home
by DoItYourself Staff
Most people do not think of humidity control until it actually starts affecting their health or the health of their house. A little planning in the area of humidity control can go a long way in determining how healthy the inhabitants of your house will be, as well as maintaining the structural integrity of your house itself.
In order to better understand humidity control, we first need to understand humidity. Humidity or relative humidity is a measure of the water vapor that is present in the atmosphere. The ideal range of relative humidity is from anywhere between 25 and 50 percent at temperatures of 68°F to 72°F. When the relative humidity is lower than this, the air is too dry, and when it is higher than this, it is too wet. So why is this a problem?
When the air is too dry, you can experience difficulty or irritation while breathing and dryness on the skin. Dry air hardens the mucus lining inside your nasal cavity. It also causes a buildup of static electricity. So is there anything that can be done to prevent this? Following are four must-have humidity control products that can resolve this issue.
Air Humidifier
An air humidifier is essential when you live in dry areas. A good way to determine if the air is too dry is to put in some ice cubes into a glass of water and wait for three minutes. If moisture does not collect outside the glass, then the air is too dry, and you should definitely invest in a humidifier. Air humidifiers can come as a part of your air conditioning system or can be retrofitted onto it. You can also purchase standalone room units.
If you think dry air is bad for your home, wait till you find out the ravages that damp air can inflict. If you find that your windows are constantly becoming fogged, notice a buildup of moisture on your walls, or experience frequent growth of mold, it’s safe to say that the humidity is too high. Higher levels of humidity are also bad for your health because they encourage the growth of mold and bacteria. You require humidity control products that will remove some of the excess moisture from the air.
Exhaust Fan
Moisture can build up in damp areas such as bathrooms and kitchens. The best way to ensure that the humidity is kept under wraps in these areas is to ensure that they are well ventilated. Install an exhaust fan in all such areas and ensure that they are switched on at regular intervals. This is to improve the ventilation of such areas and reduce humidity.
Air Conditioners
Air conditioners are invaluable when you live in areas with high humidity levels. Close all doors and windows and ensure that the air conditioner is switched on to recirculate the air inside your home. This will prevent moisture from building up.
Dehumidifiers
Dehumidifiers reduce the amount of water vapor present in the atmosphere. Many air conditioner units come fitted with dehumidifiers. However, if you air conditioner does not have one, you can purchase a separate dehumidifier unit for your home.
 forum activity
