4 Options for Homemade Stainless Steel Cleaner and Polish
Good stainless steel cleaner and polish are items you need around the house. There’s always plenty of stainless steel, and periodically, it all needs to be cleaned of dirt, finger marks and more. You can buy a stainless steel cleaner polish, but why would you want to spend the money when you can make your own? It’s not difficult, and you know exactly what goes into it rather than mysterious chemicals.
Hard Water
One of the most common problems requiring stainless steel cleaner polish is spots from hard water. If you live in a hard water area, you know the problem, and it’s unsightly. Fortunately, there’s an extremely simple answer. Take a clean, dry cloth and wet it with white vinegar. Wipe the cutlery or the pans with the cloth, and the stains will disappear. To finish, all you need to do is wash the items in warm water and then dry them with a towel.
Cleaner
This cleaner is good both for appliances as well as cookware. As the ingredients are completely natural, you can feel completely safe using it. More importantly, it works every bit as well as any commercial cleaner from the store.
Again, it’s simple. The basic recipe just makes a small quantity, but you can mix up more if necessary. Take 3 teaspoons of cream of tartar and mix that with 1 teaspoon of hydrogen peroxide. Stir together until they made a paste. Put the paste on a clean, dry cloth and rub into the stainless steel to clean it. Leave it on the appliance or pan until it’s dried. Take a fresh cloth and wet it. Use this to wipe of the paste. To complete the cleaning, you should wipe the stainless steel with yet another clean cloth in order to buff it.
Polish
After you’ve cleaned the stainless steel, you’ll want to polish it. This will help to keep the fingerprints off the steel, leaving it looking as good as the day you bought it. This is especially good for appliances; it should be used on pots and pans, where it will come in contact with heat.
Quite simply, all you need is a little lemon oil on a lint-free cloth. Rub this onto the stainless steel surface. You can use it on any surface where there is no contact with food. It gives real protection to the stainless steel surface. If you don’t have lemon oil handy at home, you can substitute baby oil. It will produce the same effect. The biggest difference is that it won’t smell as good as lemon oil.
Sinks
One of the most common things to find in a kitchen is a stainless steel sink. Most people use abrasive cleaners on these, but you don’t have to. Instead, you can put together something natural that will work just as well and with complete safety. Just mix equal parts of table salt and baking soda and use these as a stainless steel cleaner polish on the stainless steel sink.
