4 Reasons Duct Tape Is So Useful 4 Reasons Duct Tape Is So Useful
Duct tape is one of the most commonly used products in the world. With its versatility and durability, it is sometimes referred to as mankind's greatest invention. Here's why.
1. Durability
One of the biggest benefits of duct tape is its durability. Duct tape is extremely strong and durable compared to nearly any other kind of tape on the market. When you tape something up with duct tape, you know that it will hold up for a long time. It is considered a staple item in many homes and industries. Duck tape is often used to tape to tape together air ducts and will last for number of years before needing to be replaced.
2. Water Resistant
Another great reason to use duct tape is its water resistant properties. Back when duct tape was first becoming popular, the military referred to it as duck tape because water would roll off of it just like it does off of a duck's back. Most other types of tape will not be able to hold up to moisture of any kind. Duck tape can be used to cover up a hole in a water hose, saving you the cost of a new hose. You can also use duct tape as a temporary way to patch a hole in plumbing. While this is not a long-term solution, it can keep the water from leaking out until you can come up with a more permanent solution. If you have a pool, you could even use duct tape to patch a hole in the side.
3. Strength
In addition to lasting for a long time, duct tape is also very strong. You can use it for jobs that you would not be able to use any other type of tape for. With the inherent strength that duct tape provides, you will not be able to easily rip it. With the strength of the duct tape, it could potentially support a lot of weight or force without being damaged.
4. Adhesive Strength
Besides the tape itself, the adhesive on the tape is also very strong. With this adhesive strength, you can use on virtually any surface without problems. This confirms its reputation for durability and versatility.
